Date/Time: Sun, 01 Nov 2026 11:51:06 +0000
Large Integer With Suffix on VbP -Volume by Price- for profile chart values
View Count: 972
| [2021-11-23 10:45:32] |
| gjockey - Posts: 51 |
Hello, In the Volume by Price study, I have the Study settings "Value Format" dropdown set to "Large Integer With Suffix"; however, When I enable "Show Chart Values on Profile" for the VbP study, the displayed numbers are formatted as whole numbers. When the chart numbers in question are volume numbers going into the billons, it's obviously tough to read. Is there a way to enforce the "Large Integer With Suffix" setting to those volume numbers? If not, could you consider making this possible in a future version? Thank You. |
| [2021-11-23 11:02:43] |
| User907968 - Posts: 885 |
Enable this setting in the Volume by Price study - Volume By Price Study: Use Large Number Display Formatting
| [2021-11-23 11:39:46] |
Thank you so much, that did the trick. I did notice 1 value ( the POCV) that appears to be not responding to that setting. It's not a big deal for me. However, I'm leaving this image here for correction in a future update.
