Date/Time: Sat, 19 Sep 2026 12:38:30 +0000
FontBackColor input is ignored for AddAsUserDrawnDrawing = 1
View Count: 944
| [2021-11-22 23:26:04] |
| User99735 - Posts: 234 |
While trying to draw a text (DRAWING_TEXT) using s_UseTool, FontBackColor input is ignored for AddAsUserDrawnDrawing = 1. Please advice.
| [2021-11-24 16:55:29] |
Any update?
| [2021-12-06 00:19:02] |
| Sierra_Chart Engineering - Posts: 24890 |
There definitely could not be an issue because that variable is used by this study: scsf_SymbolDisplay Refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-06 01:03:50] |
scsf_SymbolDisplay uses function sc.AddAndManageSingleTextUserDrawnDrawingForStudy for adding user drawn text. The problem referred to is occurring when using s_UseTool structure and function sc.UseTool. |
| [2021-12-06 08:34:55] |
The source code for sc.AddAndManageSingleTextUserDrawnDrawingForStudy is in the SierraChart.h file. It also uses sc.UseTool. There definitely is not a problem here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-06 08:35:14
