Date/Time: Sun, 01 Nov 2026 11:51:05 +0000
Market Depth Historical Graph - is color change bar to bar possible
View Count: 885
| [2021-11-19 15:35:17] |
| User153286 - Posts: 73 |
The market depth historical graph changes colors based on ranges within a given bar by value or percentage. It is also possible to turn on the volume values at the price level to show ask/bid (max or last) traded volume. Is there a way to color or indicate a change in the traded volume value from bar to bar? For, example at a given some price level, for 10 bars, the traded max values were 250 250 250 250 250 250 250 252 157 159 127 250 to 250 no change ... 250 to 252 would go up color wise 250 to 157 would go down color wise 157 to 159 would go up.... 159 to 127 would go down.. I believe the changes from bar to bar is very telling |
| [2021-11-19 16:42:52] |
| John - SC Support - Posts: 48377 |
There is not an option to color each bar based on it's own values. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
