Date/Time: Sun, 01 Nov 2026 11:51:01 +0000
Problem when trying to modify the final data range day
View Count: 799
| [2021-11-19 15:34:44] |
| User215421 - Posts: 3 |
Hello, I'm a user of Sierra Chart since 9 months and I find it very reliable and efficient but I have a slight hitch in the data range configuration. I would traning me in price prevision. To hit this goal, I would project me in past chart and occult the recent days of the chart. So I went in the setting box to do it. The input "From" is editable but the input "To" isn't. Have you a solution to modify this limit date? If so, I will commence my new trainings. For your information, I use delayed data and I trade stocks on Nasdaq and NYSE. Thank you in advance, have a good day |
| [2021-11-19 16:41:16] |
| John - SC Support - Posts: 48377 |
In order to show data from a specific range of data, you need to use the Chart >> Chart Settings >> Use Date Range fields. You were trying to modify the Date Range in File, which can not have the "To" field edited. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
