Date/Time: Mon, 21 Sep 2026 12:30:53 +0000
I CANNOT shift out of SIM1 to trade LIVE
View Count: 1166
| [2021-11-19 15:34:29] |
| ScalpingPadawan - Posts: 6 |
I am using CQG via AMP. I have zero connection issues. When I press CTRL+SHIFT+T and click to go from SIM1 to my AMP Account number it instantly reverts back to SIM1. What is this issue, and what am I doing wrong? How do I set it so that all charts no longer say SIM1 and have me trading from my live account? Thank you! |
| [2021-11-19 16:01:51] |
Is there a check mark still by Trade >> Trade Simulation Mode On?
| [2021-11-20 14:42:52] |
That was EXACTLY the issue. Probably saved me from myself while I've been learning Sierra. I NOW consider this to be the best all-around platform and I've tried most professional and retail platforms. High learning curve, but once you see a few chartbook examples, it is fairly easy to start organizing and setting up chartbooks to your specification. I use to be anti-Sierra, but now I love it. |
| [2021-11-21 16:17:38] |
That is good.
| [2021-12-06 00:29:15] |
| tptrader - Posts: 16 |
I have CQG via AMP account. last month Sierra make me switch to Sierra but each time I turn the trade simulation off, it show a difference account and not the same account I have with AMP. how do I trade with Sierra using AMP account? |
| [2021-12-06 00:45:33] |
First follow through the CQG set up instructions here: CQG Trading Platform Service: Setup Instructions Also refer to: CQG Trading Platform Service: CQG Trading Account Numbers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
