Date/Time: Fri, 06 Nov 2026 09:06:09 +0000
Server-managed brackets...help?
View Count: 1029
[2021-11-19 00:55:19]
Mercantile_Man - Posts: 17
I don't really understand what this means, specifically how it differs to server-managed OCO, and I've read everything I can on Sierra Chart's website about it.
My understanding of server-managed OCO...
Example: When I place a buy-stop order above current price (with stop-loss and take-profit orders attached), the 'parent' buy-stop goes instantly to the exchange, and the two attached 'child' orders are sent to an intermediary server, waiting for the buy-stop to be filled, at which time they too are both sent to the exchange. Then, if the take-profit is eventually filled, the intermediary server cancels the stop-loss order (OCO).
So what is an example of how server-managed brackets work?
Thank you.
[2021-11-19 01:13:38]
How this works depends upon the particular Trading service you will be using Sierra Chart with. Let us know what that is. The supported services are listed here:
Supported Data and Trading Services: Supported Services
[2021-11-19 01:42:09]
I'm with AMP and want to use Sierra Chart's Teton Order Routing, but AMP does not yet support it.
Can you answer my question from the perspective of Teton?
Thank you.
[2021-11-19 02:10:50]
This is correct:
And this functionality occurs in under 1 millisecond.
[2021-11-19 02:14:23]
Great.
So we've established how server-managed OCO works, in the form of an example.
Could you please now do the same for server-managed brackets? I don't understand the difference.
Thank you.
[2021-11-19 10:02:56]
The description you gave is exactly how a server managed bracket order works.
Date Time Of Last Edit: 2021-11-19 10:03:17
[2021-11-19 10:35:19]
Okay, thanks.
So if an order routing service only offered server-managed brackets, the trading software would still manage the OCO function on the trader's local computer. Is that correct?
[2021-11-19 11:26:19]
There is no service that Sierra Chart supports which offers only server managed bracket orders and not server managed OCO orders.
Date Time Of Last Edit: 2021-11-19 11:26:29
