Date/Time: Fri, 06 Nov 2026 09:06:11 +0000
CQG and Rithmic
View Count: 884
| [2021-11-18 15:13:45] |
| Usernezpat - Posts: 6 |
I have a connection with CQG and Ninja trader, can i add my rythmic connection with AMP or is it either or and not both. Thanks to clarify. |
| [2021-11-18 15:33:36] |
You can use both of them with Sierra Chart. Instructions: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
