Date/Time: Fri, 06 Nov 2026 09:06:12 +0000
Out of order timestamps detected
View Count: 912
| [2021-11-18 07:43:06] |
| Kiwi - Posts: 375 |
You might want to take a look at this. I store data for hsi as 5 seconds bars. When I set the day to 00 to 23:59, no problem On a 5 second chart but not 1m and 5m. When I set the day to 11:15 to 13:59 and 15:00 to 18:29 I get OOOTs's at the beginning of the new session, 1500, (Aus Eastern time). If I shift it so that the break occurs at 10pm at night then the warnings shift too. Given the shift and that a 24hr view shows no OOOTSs I think its an artefact of the two session view. SC version 2328. Just ask if you need a file or chartbook that will show the issue. Date Time Of Last Edit: 2021-11-18 07:43:45
| [2021-11-18 07:51:41] |
| Kiwi - Posts: 375 |
It seems to only apply to one chart so I'll delete it & create a new version. Here it is in case you want to look at it. Otherwise just ignore as it no longer affects me. Date Time Of Last Edit: 2021-11-18 07:52:44
| [2021-11-18 09:53:44] |
This must be a time stamping issue with data from Interactive Brokers. We cannot help with that.
