Date/Time: Fri, 06 Nov 2026 08:53:17 +0000
AMP
View Count: 915
| [2021-11-15 15:22:42] |
| lothore - Posts: 6 |
Bonjour J'ai ouvert un compte AMP pour avoir acces au flux de donné CME (CBOT) pour pouvoir trader le Dow Jones, Nasdaq. J'aimerais savoir comment lier mon compte AMP a la plate forme Sierra pour avoir ces Flux. J'ai deja activé le flux CME non professionnel a 3 dollars par mois. Il ne me rest plus qu'a faire le lien entre AMP et sierra sur la plateforme Sierra ? |
| [2021-11-15 16:58:03] |
| John - SC Support - Posts: 48449 |
From Google Translate: I opened an AMP account to access the CME data feed (CBOT) to be able to trade the Dow Jones, Nasdaq. I would like to know how to link my AMP account to the Sierra platform to have these Feeds. I have already activated the non-professional CME feed at $ 3 per month. All I have to do is make the link between AMP and sierra on the Sierra platform?
If you are setup to use Rithmic for your order routing with AMP, then you will follow these instructions: Rithmic Trading Platform Service: Setup Instructions Otherwise, if you are setup to use CQG for your order routing with AMP, then you will follow these instructions: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
