Date/Time: Fri, 06 Nov 2026 08:53:18 +0000
Download History
View Count: 810
[2021-11-15 15:17:59]
User460426 - Posts: 6
Hey,
I am having a problem downloading historical data. My chart only loads the live data through my data feed (Rithmic).
I have already tested the following:
- I have tested different versions of Sierra Chart.
- reinstalled Sierra Chart completely
- tested another Rithmic data feed, without success
- Tested my data feed at a friend's site, it works there
- Created a new chartbook
- Adjusted all settings
- Used the Denali data feed, then it works
In the message log, I found the following error:
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-11-12 11:13:02.476
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-11-12 11:13:02.496
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-11-12 11:13:02.543
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-11-12 11:13:02.543
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-11-12 11:13:02.582
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-11-12 11:13:02.583
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-11-12 11:13:02.583
Received 5 login tokens. | 2021-11-12 11:13:02.627
Symbol settings MD5 received. Request ID: 1. | 2021-11-12 11:13:02.728
Symbol settings are up-to-date for rithmic_v2.trading. | 2021-11-12 11:13:02.728
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-11-12 11:13:03.023
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-11-12 11:13:03.023
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-11-12 11:13:03.023
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-11-12 11:13:03.023
Files to Open on Startup | Opening file: Workspace.Cht | 2021-11-12 11:13:06.738
GCZ1.COMEX [CB] 1 Min #1 | Reloading chart. | 2021-11-12 11:13:06.873
[2021-11-15 16:54:49]
Refer to the following with regards to Rithmic historical data:
Historical Data on the New Rithmic Connection
There is no error in your message log, that is just a statement about the closing of the socket, which is not a problem.
