Date/Time: Fri, 06 Nov 2026 08:53:19 +0000
How to use SC futures trading evaluator with SC data All Services ?
View Count: 844
| [2021-11-14 11:14:26] |
| Trader & Sierra++ developer - Posts: 110 |
Hi Sierra, In the "SC Data All Services" data service, there is a symbol that i need to display : $IUXX (nasdaq 100 index). But when using SC Trading Evaluator service, that symbol is not available anymore. When reading the doc i see that it is possible to use multiple services with multiple SC instances, but i'd like to avoid multiple instances to keep my setup & backup simple & easy. Is it possible to use SC main data feed ("SC data all services") simultaneously with "SC trading evaluator" service ? and how ? Thank you |
| [2021-11-15 04:17:36] |
| Sierra_Chart Engineering - Posts: 25390 |
We have added the cash indices to the Trading Evaluator service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Therefore, you can get all of this data now in a single instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-15 04:18:21
| [2021-11-15 09:35:46] |
Thank you. Then could you please also add "Futures - Euronext" to the Trading Evaluator service ? |
| [2021-11-15 18:20:02] |
No, this is unrelated. Use a separate installation of Sierra Chart for this: Using Multiple Data and Trading Services at the Same Time: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-15 19:01:02] |
great thank you. FYI the $IUXX i've added to my chartbook does not update in realtime, i need to "delete and download data" to get new data. |
| [2021-11-15 19:58:39] |
| John - SC Support - Posts: 48449 |
That symbol is part of the NASDAQ Indices. To get that as real-time data you would need to use the Sierra Chart Exchange Data Feed and activate the Nasdaq Indices exchange. Refer to the information on the following page, which includes Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
