Date/Time: Fri, 06 Nov 2026 08:53:12 +0000
Book total visibility
View Count: 719
| [2021-11-12 03:24:51] |
| User540050 - Posts: 7 |
Is there a setting to pin the total bids and offers so they are always visible on the DOM? I would like it to be the top or bottom line of the DOM respectively.
Date Time Of Last Edit: 2021-11-12 03:25:41
| [2021-11-12 13:16:38] |
This is not supported.
