Date/Time: Fri, 06 Nov 2026 08:53:10 +0000
version 2324 in ReplayChart mode
View Count: 722
| [2021-11-11 11:15:55] |
| AndreyPoroshin - Posts: 105 |
Starting from version 2324 in ReplayChart mode, the T $ S tape does not play historical information. Now you need to enable this separately in the settings?
| [2021-11-11 15:02:09] |
Set the Replay Mode to Standard: Replaying Charts: Replay Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-12 05:40:15] |
Sorry, but in standard playback mode, will I get the same quality and ideality of historical data? I will actually stay on version 2323 for now. Hope for a solution. I don't understand your recommendation, people use advanced playback settings for better results, not out of idle curiosity. If you can return the functionality to its original place and will not give advice like "use excel and not grumble", all of us, users of your wonderful program, will be happy and grateful |
