Date/Time: Fri, 06 Nov 2026 08:53:12 +0000
Charting The TUT Spread-Exchange Traded
View Count: 986
| [2021-11-09 20:48:20] |
| User841161 - Posts: 357 |
I was trying to chart the daily exchange traded TUT Spread, but doesnt look correct. Also y axis figures do not look correct. http://www.sierrachart.com/image.php?Image=1636490459717.png Tut Spread should be 2ZT-ZN, would think the chart should look like this. http://www.sierrachart.com/image.php?Image=1636490848343.png |
| [2021-11-12 05:11:38] |
| Sierra_Chart Engineering - Posts: 25390 |
Those are definitely the correct values as provided by the exchange. Although the large number of zero values do not look right. Set the chart to OHLC bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-12 05:12:56
