Date/Time: Fri, 06 Nov 2026 08:49:59 +0000
Study Question: Text Display for Study from Chart
View Count: 897
| [2021-11-09 03:18:43] |
| User486817 - Posts: 83 |
hello, i'm using the Text Display for Study from Chart on my entry charts. is it possible to display pullback column data from the Number Bars Calculated Values study on the chart. Some SGs display pullback column data but some don't as you well know, but is there a way to separately display the pullback column data for a specific SG in the Number Bars Calculated Values study? if not, may i suggest adding this feature for SGs that support pullback column data? kindest regards, |
| [2021-11-09 14:46:09] |
| John - SC Support - Posts: 48449 |
To display the Pullback column values using the Text Display for Study, just enter a -1 in the Input for Subgraph Columns Back. This capability is mentioned in the documentation for that Input in the Text Display for Study documentation, which can be found here: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-09 14:47:13
