Date/Time: Fri, 06 Nov 2026 08:47:00 +0000
Question
View Count: 806
| [2021-11-08 20:14:10] |
| User942787 - Posts: 3 |
I have package 5, began it a week plus ago, realized I need Denali Data for the additional $10. My question is can I add the data on to my current or do I have to pay the additional 46 for package 11. I just paid 36 about a week ago. Thanks. |
| [2021-11-08 21:14:53] |
| John - SC Support - Posts: 48449 |
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
