Date/Time: Fri, 06 Nov 2026 08:47:04 +0000
[User Discussion] - Cannot Connect IB/TWS to SC for Real Time Data
View Count: 773
[2021-11-08 17:26:04]
Sousa - Posts: 7
I have the port number on both SC & TWS the same, first with the default & then a second attempt with a custom port number.
Both matched exactly each time but didn't solve my problem.
I am not running a firewall but I am running Sierra Chart on a Macbook through Parallels, not sure if that makes a difference.
Thank you.
[2021-11-08 17:46:52]
We can't help you with connecting Sierra Chart to TWS through Parallels. We simply do not know enough about it to be able to have any idea of what might be happening.
We have set this as a User Discussion, hopefully there are others that have this setup that can help you.
