Date/Time: Fri, 06 Nov 2026 08:53:17 +0000
Bars using Denali not updated
View Count: 813
[2021-11-08 17:20:58]
fcpauldiaz - Posts: 18
I'm using Denali feed (SC - Data all services) but the bars are no longer being updated only the price label at the most right is being updated. What should I do ?
Here is the screen shot
http://www.sierrachart.com/image.php?Image=1636391631189.png
[2021-11-08 17:44:56]
Your chart is showing that it is fully scrolled to the right, so you should be getting the new bars.
Remove the option for Lock Fill Space if you have this enabled. Refer to the following:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
If you still have an issue after this, then get us a copy of the chart by following these instructions:
[2021-11-08 17:46:37]
User907968 - Posts: 885
Session times not correct for timezone?
