Date/Time: Fri, 06 Nov 2026 08:47:05 +0000
How to change rithmic account
View Count: 1581
| [2021-11-08 16:38:22] |
| User696827 - Posts: 15 |
How to change rithmic account from 001 to account 002?
| [2021-11-08 17:17:42] |
| John - SC Support - Posts: 48449 |
Refer to the following for how to change the Trading Account for a chart: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Keep in mind, only the accounts that are accessible through the one login that you have defined in Global Settings >> Data/Trade Service Settings are going to be available in the list of accounts as noted above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-08 17:29:13] |
but how to change in my costum DOM trading? still trading on wrong acc..... |
| [2021-11-08 17:33:02] |
whether I can delete 001 acc in the settings
| [2021-11-08 17:51:29] |
It's the same process in all cases to change the trading account. You need to open the Trade Window and change your account there. You can open the Trade Window for a Trading DOM by selecting Trade >> Open Trade Window For Chart. What do you mean by "delete 001 acc in the settings"? If you are asking how to not have it show up in your Trade Window as an option, then that is not something that we do. We simply list all the accounts that are available when you connect to your trading service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-08 18:05:12] |
oke, I caught it problem solved thank you |
