Date/Time: Fri, 06 Nov 2026 08:47:02 +0000
Error need assisatnce
View Count: 790
| [2021-11-08 06:20:56] |
| User718709 - Posts: 13 |
Hi, I haven't logged into Sierra in around 3 weeks. I'#ve just logged in, and these error messages were displayed on startup. Please advise further as to why as I have changed nothing. Thanks |
| [2021-11-08 08:13:27] |
You need to activate the exchanges you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-08 15:35:46] |
| SavantTrader - Posts: 112 |
So do an [edit][translate symbols to current service] and see what you get. Then rollover any instrument that requires it.
