Date/Time: Fri, 06 Nov 2026 08:47:00 +0000
Recenter DOM without rescaling chart
View Count: 778
[2021-11-08 00:23:50]
KylieV1618 - Posts: 79
Hi I have a hotkey to recenter all my DOMs at once.
However, when I have a DOM attached to a chart, it recenters the DOM AND rescales the chart. Which I dont want.
Is there a way to turn of the scaling of the chart, when recentering a chart DOM??
[2021-11-08 15:13:08]
You would have to have that chart set to a "Constant Range" or "User Defined Range", rather than "Automatic". Refer to the following for Constant Range:
Chart Scale and Scale Adjusting: Constant Range (Scale Range)
And here for User Defined:
Chart Scale and Scale Adjusting: User Defined (Scale Range)
