Date/Time: Thu, 26 Nov 2026 04:57:39 +0000
DOM Pulling and Stacking histogram not showing negative numbers
View Count: 1545
[2021-11-06 18:15:50]
James_Trader - Posts: 3
I noticed that the histogram of the pulling and stacking column does not show negative numbers. This is true for both the combined column and the individual columns for bid and ask.
Is there a way to set that?
imagepulling and stacking.png / V - Attached On 2021-11-06 18:07:07 UTC - Size: 356.44 KB - 489 views
[2021-11-07 15:57:27]
The histogram for the Pulling/Stacking does not display the Negative numbers. This is something we would have to add.
We have marked this as a Feature Request.
[2021-11-07 16:29:22]
stephenvosloo - Posts: 28
John, if you do add this as a feature will you allow for an option to retain the way it currently works? I much prefer that than seeing negative histogram. Thank you!
[2021-11-07 16:34:42]
Thank you for letting us know.
As always, we do not know when/if we will get to this.
[2021-11-07 20:23:05]
I see. Thank you, John!
It would be great if that could be implemented somehow. Imagine a delta at price histograms that only would show positive delta. It wouldn't be right.
The histogram itself is great because the numbers are just so difficult to judge at a glance in a fast paced market. I think the negative numbers are just as important as the positive numbers, if not more.
One way would be to have different colors for the positive and negative numbers on the histogram, like red and blue / green, like with delta at price histograms. If you make the negative histogram bars equal to the background color, you kind of get what you currently have, so that would satisfy Stephen's request.
In addition to that it could be an option to have the histogram bars stick out on different sides from the middle (left / right) depending on if they are positive or negative.
It's difficult to accurately gauge the overall market pressure in one direction or the other when the display is biased towards only one side (stacking).
So in summary: It would be great if that could be implemented!
[2021-11-07 20:31:17]
SpearChucker - Posts: 116
I look forward to this Feature being added to SC. Thanks, John.
[2026-05-15 15:16:09]
Sierra_Chart Engineering - Posts: 25491
We are looking this over.
[2026-05-29 22:29:10]
This is now fully supported in the latest prerelease. And there are separate color settings for the negative volume bars.
[2026-06-01 15:56:17]
Sébastien - Posts: 156
Thank you very much Sierra team for this awesome feature !
There is just one drawback : with v2915, the DOM bars thickness don't auto-adapt anymore with the Market Depth Combine Increment in Ticks feature.
See attached screenshot.
It was the case before and it was very useful for NQ Bid/Ask depth, Pull Stack and Recent volume columns.
It was less useful for all the Current volume columns since finer granularity is usually a good thing for NQ (just my 2ct opinion).
Ideally, this feature should be activable/deactivable by column.
Could you please bring back this functionality ?
imageScreenshot 2026-06-01 172447.png / V - Attached On 2026-06-01 15:30:24 UTC - Size: 18.56 KB - 183 views
[2026-06-01 19:00:39]
This is controlled by "Trade >> Trade DOM Settings >> Other >> Chart DOM Volume Bars Fill Combined Price Level".
But this is global, and not per column.
[2026-06-01 19:34:34]
Thank you ! I Didn't spotted this new parameter.
