Date/Time: Fri, 06 Nov 2026 08:47:11 +0000
Order rejected
View Count: 801
[2021-11-06 17:54:42]
User202861 - Posts: 1
I have posted my message log about my orders have been rejected.
could you pease help me to find out what was the reason?
I have posted the message log not long ago.
Thank you.
imagelog061121.jpg / V - Attached On 2021-11-06 17:49:58 UTC - Size: 2.32 MB - 233 views
[2021-11-07 15:27:21]
In the log file you sent, you are having connectivity issues. You have the following message throughout your log:
DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
For more information about this, refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
From the image you provided, you have the messages:
New Order Rejected - BitMEX Trading Direct Error: Access Denied...
You would need to ask BitMEX about this. For some reason they are denying access for your account.
