Date/Time: Fri, 06 Nov 2026 08:53:12 +0000
[User Discussion] - Wav file will not play on SC but does on windows player
View Count: 1402
[2021-11-05 22:24:44]
VolTrader73 - Posts: 139
Hello.
Was researching this issue as I added my text to speech WAV files to the SC alert folder and can choose them from the general settings but they will not play. I read through some of the posts and I have also the windows error code 122 issue but:
I can play them with windows media player.
I have them in 3 formats but they still dont play:
11 Khz 16 bit mono
16 Khz 8 bit mono
16 Khz 16 bit stereo
Example name scalp-shot.wav, scalpshort.wav, scalp.wav
No matter what, after selecting the wav file from the SC Alert folder (I placed them there), applying them to any of the Alert# and clicking the test sound button , all I get is some default window sound. I tried clicking ok after applying and reopen the general settings/alert and see the right file name assigned to the right alert# but still when testing it will not play.
Is it even possible to use user created alerts or only those created through your text to wav service ??
Please advise
[2021-11-06 12:27:23]
This is not within the scope of our support. You need to determine what the problem is. We do not know.
[2021-11-06 20:39:11]
ForgivingComputers.com - Posts: 1251
11 Khz 16 bit mono
16 Khz 8 bit mono
See if you can convert these to 22050 Hz 32-bit float. Mono or Stereo. That format works.
[2021-11-07 13:04:20]
Marmany - Posts: 319
I use the standard W10 text to speech app and save as Wav file.
The files play as Sierra Alerts.
[2021-11-10 14:03:26]
Hello.
Thank you Bradh and Marmany.
Brahd - any windows app for that ?
Marmany -
I found the text to speech settings and can see the small ruler when win+h but how do I save anything ? or is there an app you mean specifically ?
Date Time Of Last Edit: 2021-11-10 14:17:08
[2021-11-10 14:09:15]
I would look into Audacity. Not sure if it will do exactly what you want, but it is free and worth a try.
BradH
[2021-11-10 15:14:23]
I thought the app came with windows 10 but apparently
I am using the yunus app.
https://www.microsoft.com/en-us/p/convert-text-to-speech/9wzdncrddlsc?activetab=pivot:overviewtab
[2021-11-12 10:56:39]
Thank you all fellow members you have solved the problem!
