Date/Time: Fri, 06 Nov 2026 08:47:10 +0000
Crude oil data
View Count: 1591
| [2021-11-04 18:53:04] |
| User558455 - Posts: 70 |
Hello, Hope All is well with the SC team. I need some help to get live data for /CL Crude oil futures data. I am current using " SC services all data" and unable to get live data. Current it shows delayed data and wont update. Thank you for the help as always |
| [2021-11-04 20:27:12] |
You need to activate the NYMEX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
