Date/Time: Fri, 06 Nov 2026 08:47:11 +0000
Why is the difference between delta bars on two different feeds?
View Count: 896
[2021-11-04 17:59:27]
hr719 - Posts: 26
So, I have account with a prop firm Leeloo Trading and personal account with AMP Futures. Leeloo data is through rithmic pro and AMP data is through CQG.
As you can see below in the attached files, the delta Vol per bar charts don't match and they are set on the same settings. Both are set to MES futures contract and both are set to 400 delta charts. As you can see at the end of the chart AMP is showing one big bar, where as Leeloo is showing multiple broken bars. Why is this happening?
Date Time Of Last Edit: 2021-11-04 18:02:04
imageleeloo.png / V - Attached On 2021-11-04 17:58:11 UTC - Size: 32.01 KB - 261 views
imageAmp.png / V - Attached On 2021-11-04 17:58:19 UTC - Size: 10.75 KB - 284 views
[2021-11-04 18:16:58]
We can not help with data issues from sources other than our own. All we can say is that we are displaying the information we receive.
