Date/Time: Fri, 06 Nov 2026 09:02:51 +0000
CTRL/ALT Chart DOM hotkey messing up scaling hotkey
View Count: 1436
| [2021-11-03 14:32:20] |
| Mauro - Posts: 48 |
Hello, I am trying to use the "Extend Chart DOM across Entire Chart when using CTRL/ALT" functionality. I like the idea but as soon as I activate it I loose the CTRL key for the chart interactive scaling. Is there a way to change the hotkey functions for one or both of those tasks to something different than CTRL? Thank you M |
| [2021-11-09 01:11:05] |
| Sierra_Chart Engineering - Posts: 25390 |
We will check on this and see what we can do.
| [2021-11-16 03:55:12] |
We have implemented a solution to this which will be out in the next release.
