Date/Time: Fri, 06 Nov 2026 08:40:03 +0000
Different UDP ports for 2 Sierras running
View Count: 820
| [2021-11-02 07:49:47] |
| User97684 - Posts: 136 |
Hi, Pls help - I have 2 different Sierra copies working. One is on Rithmic + Denali , other on CQG + Eurex from Sierra Under sierra chart server settings I have the same UDP port number on both Shall I make them different, say by +1 ? Many thanks |
| [2021-11-02 11:19:47] |
Set both UDP ports to 0. They are not needed.
