Date/Time: Fri, 06 Nov 2026 08:40:02 +0000
Can I highlight large resting bid/ask orders on Chart DOM?
View Count: 2502
[2021-11-01 16:31:32]
User755495 - Posts: 16
Can I highlight quantities in the buy/bid column of a chart DOM that are greater than a specified amount (e.g., >299) by assigning a different color to any resting order quantity meeting the specified threshhold? Same for quantities in the sell/ask column.
I've searched for a setting that will do this and have been unable to locate one, and have also been unable to find an answer to this question in the support questions & answers.
Thanks for your help!
imagechart DOM resting order highlights.jpg / V - Attached On 2021-11-01 16:30:46 UTC - Size: 116.52 KB - 692 views
[2021-11-01 17:10:38]
There is not a way to do this on the DOM. But you can use the Market Depth Historical Graph to do this. Just set the Minimum Quantity for coloring to the value above which you want to see the values and adjust the rest of your settings as needed. You can also set the display to just show values to the right side of the graph so you can push it up against the DOM.
Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph
