Date/Time: Fri, 06 Nov 2026 08:40:08 +0000
Large Volume Trade Indicator - Overlay
View Count: 1396
| [2021-10-31 17:14:51] |
| SavantTrader - Posts: 112 |
Dear Support, I understand that only one LVTI study can be used per chart, due to the data it has to collect. Is there a way to overlay LVTI indicators from one chart to another? I would like to get around this limitation by creating 3 charts that each use a different LVTI threshold value, and then overlay/display these LVTI on a main chart. I've tried [Study Price Overlay], [Study Overlay - OHLC], and a few others to no avail. Is there a way of accomplishing what I want to do? |
| [2021-10-31 18:06:11] |
| John - SC Support - Posts: 48449 |
If you want to see the value per bar, then those values can be viewed on another chart by using the Study/Price Overlay to get the study information into the chart (you will not be able to see the data directly with the Study/Price Overlay and then you can use the Study Subgraph Above/Below Bar as Text. You would then reference one of the Subgraphs from the Study/Price Overlay, depending on which one you want to see. You will see that there are only 4 subgraphs that you can view, those are the only ones for which you will be able to do this. The data with multiple values per bar are special and can not be viewed in another chart in this way. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
