Date/Time: Fri, 06 Nov 2026 08:40:01 +0000
[User Discussion] - 2 Images folders in Sierra CHart
View Count: 877
[2021-10-30 18:06:45]
58LesPaul - Posts: 429
I noticed I have 2 Images folder in Sierra Chart. One is Sierra Chart > Images which I believe is the normal one and the other is Sierra Chart > Graphics > Images which has an ImageLog file which is what I have always seen in the Image folder, but I believe its location is wrong. Is there an issue here? Do I need to delete one of them? If so, which one? I'm almost certain the one with the ImageLog is the correct folder but in the wrong place.
[2021-10-31 16:32:04]
Go to Global Settings >> General Settings and see what the Chart Image Folder is set to. Be sure to do this for all instances of Sierra Chart that you run (that is, if you run Sub-Instances, make sure you check them as well to see if one may be set to an odd folder).
Whichever folder is not being referenced is the one you can remove.
Just keep in mind that /SierraChart/Graphics is a valid folder, so do not remove that one, just the images folder under it, if you need/want to.
