Date/Time: Fri, 06 Nov 2026 08:40:54 +0000
Chart Trading Order Lines during replay
View Count: 799
| [2021-10-30 06:41:14] |
| Tony - Posts: 732 |
Hi, Is it possible that Order Lines (limit, stop etc) can also be shown on the chart during replay (as position lines) ? Thanks! |
| [2021-10-30 14:38:42] |
No, there is no support for this.
