Date/Time: Fri, 06 Nov 2026 08:40:07 +0000
opening file in chartbook
View Count: 1011
| [2021-10-29 22:25:59] |
| User312718 - Posts: 26 |
I'm trying to access NumbersBarsExampleChartbook.cht that I downloaded. I save it to sierra data folder but it does not appear there.
Attachment Deleted. |
| [2021-10-30 12:43:57] |
| ForgivingComputers.com - Posts: 1251 |
It looks like you opened the Sierra Chart Installer. If Sierra Chart is not installed, then you need to finish installing. If or when it is installed you then do File>>Open Chartbook. You cannot double-click on a CHT file and have it open in Sierra Chart.
