Date/Time: Fri, 06 Nov 2026 08:40:07 +0000
New problem: Sending Message Log for Analysis
View Count: 837
[2021-10-29 17:25:19]
owendonk - Posts: 54
Today my rithmic login exceeded 100 attached accounts. Afterwards, Sierra Chart was not able to connect to the trading service. I can still login to trading service just fine with Rithmic Trader Pro so I don't think it's on their end.
I suspect you have a hardcoded limit at 100 accounts? That's what I would do if I were programming it in because that's an absurd number. I have 20 active accounts that I'm using with Order Allocation to Trade Accounts. The rest can be deleted and I'm contacting Rithmic to do that. In the meantime can you respond to my 100 limit theory?
I will update this post when deleting extra accounts has been tested. Until then here is the Message Log, with relevant line in bold.
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 13:12:26.588
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 13:12:26.590
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 13:12:26.591
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 13:12:26.591
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 13:12:26.591
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 13:12:26.657
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 13:12:26.657
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 13:12:26.657
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 13:12:26.657
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 13:12:26.667
DTC Client socket (1) | CloseSocket call. | 2021-10-29 13:12:26.672
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 13:12:26.672
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 13:12:26.672
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 13:12:26.673
DTC Client socket (1) | Closed. | 2021-10-29 13:12:26.673
WSACleanup called. | 2021-10-29 13:12:26.944
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 13:12:26.946
DTC Client socket (0) | CloseSocket call. | 2021-10-29 13:12:26.946
Rithmic Direct - DTC | Disconnected. | 2021-10-29 13:12:26.947
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 13:12:26.947
Date Time Of Last Edit: 2021-10-29 17:32:15
[2021-10-29 17:42:57]
After deleting accounts until number is under 100, I can connect and there are no problems. My theory may have been right.
[2021-10-29 18:15:15]
There has been a general problem with connectivity to Rithmic. It has been up and down and we do not know the current status.
We have no idea about the number of accounts, that is something Rithmic would control, not us.
