Date/Time: Fri, 06 Nov 2026 08:40:00 +0000
Cannot connect
View Count: 910
[2021-10-29 15:59:51]
xyzeee - Posts: 8
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-10-29 08:41:34.385
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-10-29 08:41:34.385
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-10-29 08:41:34.385
Created the DTC Protocol server. | 2021-10-29 08:41:34.415
DTC Protocol Server listening on port 11099. | 2021-10-29 08:41:34.416
Reading Internal Order ID file. | 2021-10-29 08:41:34.417
Reading Trade Orders file. | 2021-10-29 08:41:34.486
Reading Trade Positions file. | 2021-10-29 08:41:34.486
Reading Trade Account Data files. | 2021-10-29 08:41:34.486
UDPListener (1408). Port 22904 | Listening on UDP port 22904. | 2021-10-29 08:41:34.503
Software version: 2320 64-bit | 2021-10-29 08:41:34.504
Primary Thread ID: 24092 | 2021-10-29 08:41:34.504
Usage end date: 2021-11-26 | 2021-10-29 08:41:34.504
Enabled for: Advanced Features 2. | 2021-10-29 08:41:34.504
Enabled for: Sierra Chart Historical Data Service. | 2021-10-29 08:41:34.504
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-10-29 08:41:34.504
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-10-29 08:41:34.504
Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-29 08:41:34.504
Enabled for exchange2: CME | 2021-10-29 08:41:34.504
Enabled for exchange2: fairx_exchange.data | 2021-10-29 08:41:34.504
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-29 08:41:34.504
Current selected Data/Trading service: Rithmic Direct - DTC | 2021-10-29 08:41:34.504
Custom symbol settings values: enabled | 2021-10-29 08:41:34.504
Chart Update Interval: 500 | 2021-10-29 08:41:34.504
Intraday Data Storage Time Unit: 0 | 2021-10-29 08:41:34.504
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-10-29 08:41:34.504
2021-10-29 15:41:34 Local computer time in UTC | 2021-10-29 08:41:34.504
2021-10-29 08:41:34 Local computer time in SC Time Zone | 2021-10-29 08:41:34.504
2021-10-29 15:41:33 Server time in UTC | 2021-10-29 08:41:34.504
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-10-29 08:41:34.504
Program path: C:\SierraChart\ | 2021-10-29 08:41:34.504
Data Files path: C:\SierraChart\Data\ | 2021-10-29 08:41:34.504
OS Version Number: 10.0 | 2021-10-29 08:41:34.504
Locale Setting: C | 2021-10-29 08:41:34.504
DLLs: MainSystem_64.dll, OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, UserContributedStudies_64.dll | 2021-10-29 08:41:34.504
Allowed protected custom studies: OrderFlowLabs.com, OrderFlowLabs.com Beta | 2021-10-29 08:41:34.504
Created the DTC Protocol historical data server. | 2021-10-29 08:41:34.519
HD Server Manager | Listening on port 11098. | 2021-10-29 08:41:34.521
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-10-29 08:41:34.521
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-10-29 08:41:34.529
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-10-29 08:41:34.720
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-10-29 08:41:34.720
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-10-29 08:41:34.811
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-10-29 08:41:34.811
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 08:41:34.811
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-10-29 08:41:34.812
Received 5 login tokens. | 2021-10-29 08:41:35.127
Symbol settings MD5 received. Request ID: 1. | 2021-10-29 08:41:35.403
Symbol settings are up-to-date for rithmic_v2.trading. | 2021-10-29 08:41:35.404
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 08:41:41.387
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 08:41:41.389
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 08:41:41.389
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 08:41:41.389
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 08:41:41.389
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 08:41:41.465
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 08:41:41.465
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 08:41:41.466
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 08:41:41.466
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 08:41:41.544
DTC Client socket (1) | CloseSocket call. | 2021-10-29 08:41:41.544
DTC Client socket (1) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 08:41:41.545 *
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 08:41:41.545
DTC Client socket (1) | Closed. | 2021-10-29 08:41:41.545
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 08:41:41.545
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 08:41:41.545
WSACleanup called. | 2021-10-29 08:41:41.572
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 08:41:41.572
DTC Client socket (0) | CloseSocket call. | 2021-10-29 08:41:41.573
Rithmic Direct - DTC | Disconnected. | 2021-10-29 08:41:41.573
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 08:41:41.573
[2021-10-29 16:23:05]
There is some issue with Rithmic at this time.
[2021-10-29 16:44:49]
We have heard back from Rithmic and they state that they have fixed the issue. You should be able to connect now.
[2021-10-29 17:15:17]
xyzeee - Posts: 8
It was good for a few minutes, now the issue is back.
[2021-10-29 17:17:34]
madness99 - Posts: 35
Same here. It stopped working again.
[2021-10-29 17:22:30]
You need to contact Rithmic and let them know you are having an issue again. This is definitely a Rithmic issue.
