Date/Time: Fri, 06 Nov 2026 08:40:54 +0000
Connection suddenly fails (Rhitmic)
View Count: 807
| [2021-10-29 14:56:38] |
| User727370 - Posts: 2 |
Message log HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-10-29 10:46:42.324 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-10-29 10:46:42.325 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-10-29 10:46:42.325 Reading Internal Order ID file. | 2021-10-29 10:46:42.506 Reading Trade Orders file. | 2021-10-29 10:46:42.811 Reading Trade Positions file. | 2021-10-29 10:46:42.812 Reading Trade Account Data files. | 2021-10-29 10:46:42.813 UDPListener (1464). Port 22903 | Listening on UDP port 22903. | 2021-10-29 10:46:43.042 Software version: 2299 64-bit | 2021-10-29 10:46:43.043 Primary Thread ID: 13568 | 2021-10-29 10:46:43.043 Usage end date: 2021-11-18 | 2021-10-29 10:46:43.043 Enabled for: Sierra Chart Historical Data Service. | 2021-10-29 10:46:43.043 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-10-29 10:46:43.043 Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-29 10:46:43.043 Enabled for exchange2: fairx_exchange.data | 2021-10-29 10:46:43.043 Allow Support for Sierra Chart Data Feeds is disabled. | 2021-10-29 10:46:43.043 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-10-29 10:46:43.043 Custom symbol settings values: enabled | 2021-10-29 10:46:43.043 Chart Update Interval: 40 | 2021-10-29 10:46:43.043 Intraday Data Storage Time Unit: 1 | 2021-10-29 10:46:43.043 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-10-29 10:46:43.043 2021-10-29 14:46:43 Local computer time in UTC | 2021-10-29 10:46:43.043 2021-10-29 10:46:43 Local computer time in SC Time Zone | 2021-10-29 10:46:43.043 2021-10-29 14:46:51 Server time in UTC | 2021-10-29 10:46:43.043 Local computer UTC time and Server UTC time difference: 11 seconds. | 2021-10-29 10:46:43.043 Notice: Your computer's clock is off by 11 seconds. For help with this, press the 'Send for Analysis' button. | 2021-10-29 10:46:43.043 Program path: D:\SierraChartTransActMA\ | 2021-10-29 10:46:43.043 Data Files path: D:\SierraChartTransActMA\Data\ | 2021-10-29 10:46:43.043 OS Version Number: 10.0 | 2021-10-29 10:46:43.043 Locale Setting: C | 2021-10-29 10:46:43.043 DLLs: Trade29CustomStudies.dll, Trade29CustomStudies_2151_64.dll, Trade29CustomStudies_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2021-10-29 10:46:43.044 Allowed protected custom studies: Trade29 Custom Studies | 2021-10-29 10:46:43.044 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-10-29 10:46:43.270 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-10-29 10:46:43.757 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-10-29 10:46:43.789 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-10-29 10:46:43.792 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:46:43.792 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-10-29 10:46:43.792 Received 5 login tokens. | 2021-10-29 10:46:43.955 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-10-29 10:46:43.979 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-10-29 10:46:43.979 Symbol settings MD5 received. Request ID: 1. | 2021-10-29 10:46:44.474 Symbol settings are up-to-date for rithmic_v2.trading. | 2021-10-29 10:46:44.474 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:46:50.251 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:46:50.254 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:46:50.255 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:46:50.255 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:46:50.255 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:46:50.424 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:46:50.424 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:46:50.424 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:46:50.424 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:46:50.588 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:46:50.588 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:46:50.588 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:46:50.588 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:50.588 WSACleanup called. | 2021-10-29 10:46:50.603 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:46:50.604 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:46:50.605 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:46:50.605 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:50.605 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:46:50.753 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:46:50.753 DTC Client socket (1) | Closed. | 2021-10-29 10:46:50.753 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:46:54.629 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:46:54.632 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:46:54.633 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:46:54.633 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:46:54.633 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:46:54.803 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:46:54.803 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:46:54.803 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:46:54.803 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:46:54.969 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:46:54.969 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:46:54.969 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:46:54.969 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:54.969 WSACleanup called. | 2021-10-29 10:46:54.982 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:46:54.983 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:46:54.983 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:46:54.983 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:54.983 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:46:55.136 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:46:55.136 DTC Client socket (1) | Closed. | 2021-10-29 10:46:55.136 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:46:59.006 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:46:59.009 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:46:59.010 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:46:59.010 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:46:59.010 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:46:59.178 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:46:59.178 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:46:59.178 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:46:59.178 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:46:59.342 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:46:59.342 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:46:59.342 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:46:59.342 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:59.342 WSACleanup called. | 2021-10-29 10:46:59.359 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:46:59.360 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:46:59.360 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:46:59.360 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:46:59.360 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:46:59.506 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:46:59.506 DTC Client socket (1) | Closed. | 2021-10-29 10:46:59.506 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:03.379 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:03.388 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:03.392 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:03.394 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:03.394 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:03.561 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:03.561 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:03.561 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:03.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:03.723 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:03.723 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:03.723 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:03.723 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:03.723 WSACleanup called. | 2021-10-29 10:47:03.746 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:03.747 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:03.748 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:03.748 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:03.748 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:03.885 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:03.886 DTC Client socket (1) | Closed. | 2021-10-29 10:47:03.886 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:07.764 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:07.767 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:07.770 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:07.771 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:07.771 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:07.940 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:07.940 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:07.940 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:07.940 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:08.111 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:08.112 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:08.112 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:08.112 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:08.112 WSACleanup called. | 2021-10-29 10:47:08.132 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:08.133 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:08.134 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:08.134 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:08.134 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:08.271 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:08.271 DTC Client socket (1) | Closed. | 2021-10-29 10:47:08.271 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:12.135 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:12.138 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:12.139 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:12.141 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:12.141 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:12.310 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:12.310 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:12.310 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:12.310 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:12.512 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:12.512 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:12.512 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:12.512 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:12.512 WSACleanup called. | 2021-10-29 10:47:12.533 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:12.535 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:12.535 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:12.535 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:12.535 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:12.640 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:12.641 DTC Client socket (1) | Closed. | 2021-10-29 10:47:12.641 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:16.535 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:16.538 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:16.587 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:16.587 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:16.587 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:16.897 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:16.897 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:16.897 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:16.897 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:16.991 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:17.155 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:17.155 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:17.155 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:17.171 WSACleanup called. | 2021-10-29 10:47:17.181 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:17.182 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:17.182 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:17.182 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:17.182 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:17.374 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:17.374 DTC Client socket (1) | Closed. | 2021-10-29 10:47:17.374 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:21.187 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:21.191 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:21.192 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:21.192 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:21.193 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:21.365 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:21.365 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:21.365 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:21.365 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:21.531 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:21.532 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:21.532 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:21.532 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:21.532 WSACleanup called. | 2021-10-29 10:47:21.556 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:21.557 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:21.558 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:21.558 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:21.558 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:21.705 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:21.705 DTC Client socket (1) | Closed. | 2021-10-29 10:47:21.706 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:25.586 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:25.590 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:25.590 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:25.591 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:25.591 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:25.758 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:25.758 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:25.758 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:25.758 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:25.923 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:25.923 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:25.923 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:25.923 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:25.923 WSACleanup called. | 2021-10-29 10:47:25.939 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:25.940 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:25.940 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:25.940 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:25.940 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:26.087 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:26.087 DTC Client socket (1) | Closed. | 2021-10-29 10:47:26.087 File >> Disconnect selected. | 2021-10-29 10:47:26.682 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:26.682 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:26.682 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:47:30.187 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:47:30.189 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:47:30.190 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:47:30.190 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:47:30.190 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:47:30.355 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:47:30.355 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:47:30.356 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:47:30.356 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:47:30.518 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:47:30.518 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:47:30.518 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:47:30.518 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:30.518 WSACleanup called. | 2021-10-29 10:47:30.540 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:47:30.541 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:30.541 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:30.541 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:47:30.542 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:47:30.681 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:47:30.681 DTC Client socket (1) | Closed. | 2021-10-29 10:47:30.681 File >> Disconnect selected. | 2021-10-29 10:47:33.554 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:47:33.554 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:47:33.554 WSACleanup called. | 2021-10-29 10:48:07.571 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. | 2021-10-29 10:48:07.577 Current selected Data/Trading service: CQG WebAPI | 2021-10-29 10:48:07.577 Symbol settings MD5 received. Request ID: 2. | 2021-10-29 10:48:08.665 Requested symbol settings for service code cqg. Request ID: 3. | 2021-10-29 10:48:08.666 Symbol settings received. Request ID: 3. | 2021-10-29 10:48:10.471 CQG WebAPI | Connecting to server api.cqg.com | 2021-10-29 10:48:10.921 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-10-29 10:48:10.921 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:11.710 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:48:11.710 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-10-29 10:48:11.710 CQG WebSocket | Opening WebSocket. | 2021-10-29 10:48:11.870 CQG WebSocket | Sending WebSocket handshake. | 2021-10-29 10:48:11.870 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-29 10:48:12.362 CQG WebSocket | Server header | Connection: upgrade | 2021-10-29 10:48:12.362 CQG WebSocket | Server header | Sec-WebSocket-Accept: hFtOWM86gcmY+SjsbRqMHrV1h5s= | 2021-10-29 10:48:12.362 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-10-29 10:48:12.362 CQG WebSocket | Server header | Upgrade: websocket | 2021-10-29 10:48:12.362 CQG WebSocket | Server header | | 2021-10-29 10:48:12.362 CQG WebSocket | Web socket state is now open. | 2021-10-29 10:48:12.362 CQG WebAPI | WebSocket connected. | 2021-10-29 10:48:12.362 CQG WebAPI | Sending market data logon message. | 2021-10-29 10:48:12.362 CQG WebAPI | Base Time: 2021-10-24T20:15:17. 2021-10-24 20:15:17 | 2021-10-29 10:48:12.636 CQG WebAPI | Logon successful. Session Token = oDNVWAfDfj+/AXw3JR48Jv7blTvEAXWy0gmBmaXlQH0iR59hV63uw89Y5n6wTju8RxbJVJlOtdv | 2021-10-29 10:48:12.636 CQG WebAPI | Connected to server complete. | 2021-10-29 10:48:12.636 Triggering next historical data download in queue. | 2021-10-29 10:48:12.638 Triggering next historical data download in queue. | 2021-10-29 10:48:12.638 Triggering next historical data download in queue. | 2021-10-29 10:48:12.638 Triggering next historical data download in queue. | 2021-10-29 10:48:12.638 Updated verified funded futures trading account ending date to: 2021-11-28 14:48:12 | 2021-10-29 10:48:12.644 CQG WebAPI | Sending Trade Accounts request message. | 2021-10-29 10:48:12.688 No download requests in the queue to start downloads for. | 2021-10-29 10:48:12.688 No download requests in the queue to start downloads for. | 2021-10-29 10:48:12.688 No download requests in the queue to start downloads for. | 2021-10-29 10:48:12.688 No download requests in the queue to start downloads for. | 2021-10-29 10:48:12.688 CQG WebAPI | Brokerage name: AMP. Account Name: 119381 | 2021-10-29 10:48:12.899 Updated verified funded futures trading account ending date to: 2021-11-28 14:48:12 | 2021-10-29 10:48:12.899 CQG WebAPI | Sending collateral subscribe request. | 2021-10-29 10:48:12.899 File >> Disconnect selected. | 2021-10-29 10:48:16.681 CQG WebAPI | Sending Web API Logoff message. | 2021-10-29 10:48:16.681 CQG WebSocket socket (1) | CloseSocket call. | 2021-10-29 10:48:16.681 CQG WebSocket | WebSocket closed. | 2021-10-29 10:48:16.681 CQG WebAPI | WebSocket closed. | 2021-10-29 10:48:16.681 CQG WebAPI | Disconnected. | 2021-10-29 10:48:16.681 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:16.682 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:16.839 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-10-29 10:48:16.839 CQG WebSocket socket (0) | CloseSocket call. | 2021-10-29 10:48:31.179 CQG WebSocket socket (0) | CloseSocket call. | 2021-10-29 10:48:31.180 CQG WebSocket socket (0) | CloseSocket call. | 2021-10-29 10:48:31.181 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:31.184 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2021-10-29 10:48:31.184 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Connecting to IP: 38.79.0.89. | 2021-10-29 10:48:31.185 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 4. | 2021-10-29 10:48:31.185 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-10-29 10:48:31.185 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:31.797 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | CloseSocket call. | 2021-10-29 10:48:31.797 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:31.797 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Closed. | 2021-10-29 10:48:31.797 Symbol settings MD5 received. Request ID: 4. | 2021-10-29 10:48:32.155 Requested symbol settings for service code rithmic_v2.trading. Request ID: 5. | 2021-10-29 10:48:32.155 Symbol settings received. Request ID: 5. | 2021-10-29 10:48:33.762 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:34.228 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:34.231 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:34.232 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-10-29 10:48:34.232 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:34.232 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:34.401 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:34.401 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:34.401 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:34.401 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-10-29 10:48:34.565 DTC Client socket (3) | CloseSocket call. | 2021-10-29 10:48:34.565 DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:34.565 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:34.565 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:34.566 WSACleanup called. | 2021-10-29 10:48:34.586 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:34.587 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:34.587 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:34.587 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:34.587 DTC Client socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:34.728 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:34.729 DTC Client socket (3) | Closed. | 2021-10-29 10:48:34.729 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:38.597 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:38.600 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:38.601 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:48:38.601 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:38.601 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:38.770 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:38.770 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:38.771 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:38.771 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:38.933 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:48:38.933 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:38.933 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:38.934 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:38.934 WSACleanup called. | 2021-10-29 10:48:38.949 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:38.950 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:38.950 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:38.950 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:38.950 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:39.098 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:39.099 DTC Client socket (2) | Closed. | 2021-10-29 10:48:39.099 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:42.966 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:42.969 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:42.969 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:48:42.970 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:42.970 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:43.140 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:43.140 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:43.141 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:43.141 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:43.303 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:48:43.303 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:43.303 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:43.304 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:43.304 WSACleanup called. | 2021-10-29 10:48:43.317 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:43.318 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:43.318 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:43.318 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:43.318 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:43.467 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:43.467 DTC Client socket (2) | Closed. | 2021-10-29 10:48:43.467 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:47.317 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:47.320 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:47.321 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:48:47.321 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:47.321 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:47.491 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:47.491 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:47.491 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:47.491 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:47.657 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:48:47.657 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:47.657 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:47.657 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:47.657 WSACleanup called. | 2021-10-29 10:48:47.669 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:47.670 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:47.670 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:47.670 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:47.670 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:47.823 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:47.823 DTC Client socket (2) | Closed. | 2021-10-29 10:48:47.823 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:51.681 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:51.684 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:51.685 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:48:51.685 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:51.685 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:51.854 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:51.854 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:51.854 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:51.854 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:52.019 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:48:52.019 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:52.019 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:52.019 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:52.019 WSACleanup called. | 2021-10-29 10:48:52.033 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:52.034 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:52.034 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:52.034 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:52.034 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:52.184 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:52.184 DTC Client socket (2) | Closed. | 2021-10-29 10:48:52.184 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:48:56.032 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:48:56.036 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:48:56.036 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:48:56.037 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:48:56.037 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:48:56.203 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:48:56.203 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:48:56.203 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:48:56.203 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:48:56.364 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:48:56.364 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:48:56.364 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:48:56.364 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:56.364 WSACleanup called. | 2021-10-29 10:48:56.384 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:48:56.385 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:48:56.385 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:48:56.385 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:48:56.385 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:48:56.525 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:48:56.525 DTC Client socket (2) | Closed. | 2021-10-29 10:48:56.526 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:00.385 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:00.388 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:00.389 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:00.389 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:00.390 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:00.557 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:00.557 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:00.557 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:00.557 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:00.720 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:00.721 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:00.721 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:00.721 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:00.721 WSACleanup called. | 2021-10-29 10:49:00.739 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:00.740 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:00.740 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:00.740 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:00.740 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:00.891 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:00.891 DTC Client socket (2) | Closed. | 2021-10-29 10:49:00.891 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:04.741 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:04.744 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:04.745 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:04.745 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:04.745 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:04.912 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:04.912 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:04.912 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:04.912 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:05.076 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:05.076 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:05.076 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:05.076 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:05.076 WSACleanup called. | 2021-10-29 10:49:05.092 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:05.093 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:05.093 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:05.093 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:05.093 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:05.244 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:05.244 DTC Client socket (2) | Closed. | 2021-10-29 10:49:05.244 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:09.109 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:09.112 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:09.113 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:09.113 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:09.113 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:09.279 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:09.279 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:09.279 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:09.279 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:09.441 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:09.441 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:09.441 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:09.441 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:09.441 WSACleanup called. | 2021-10-29 10:49:09.460 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:09.462 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:09.462 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:09.462 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:09.462 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:09.602 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:09.602 DTC Client socket (2) | Closed. | 2021-10-29 10:49:09.602 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:13.461 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:13.465 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:13.465 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-10-29 10:49:13.466 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:13.466 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:13.631 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:13.632 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:13.632 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:13.632 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-10-29 10:49:13.794 DTC Client socket (3) | CloseSocket call. | 2021-10-29 10:49:13.795 DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:13.795 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:13.795 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:13.795 WSACleanup called. | 2021-10-29 10:49:13.814 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:13.815 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:13.816 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:13.816 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:13.816 DTC Client socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:13.969 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:13.969 DTC Client socket (3) | Closed. | 2021-10-29 10:49:13.969 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:17.812 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:17.815 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:17.816 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:17.816 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:17.816 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:17.984 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:17.984 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:17.984 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:17.984 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:18.149 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:18.149 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:18.149 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:18.149 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:18.149 WSACleanup called. | 2021-10-29 10:49:18.163 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:18.164 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:18.164 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:18.164 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:18.164 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:18.312 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:18.312 DTC Client socket (2) | Closed. | 2021-10-29 10:49:18.312 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:22.178 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:22.182 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:22.182 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:22.183 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:22.183 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:22.348 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:22.348 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:22.348 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:22.348 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:22.508 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:22.508 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:22.508 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:22.508 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:22.508 WSACleanup called. | 2021-10-29 10:49:22.516 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:22.517 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:22.518 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:22.518 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:22.518 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:22.670 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:22.670 DTC Client socket (2) | Closed. | 2021-10-29 10:49:22.670 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:26.522 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:26.526 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:26.526 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:26.527 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:26.527 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:26.694 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:26.694 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:26.694 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:26.694 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:26.859 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:26.860 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:26.860 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:26.860 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:26.860 WSACleanup called. | 2021-10-29 10:49:26.874 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:26.875 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:26.876 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:26.876 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:26.876 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:27.025 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:27.025 DTC Client socket (2) | Closed. | 2021-10-29 10:49:27.025 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:30.870 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:30.873 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:30.873 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:30.874 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:30.874 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:31.039 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:31.039 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:31.039 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:31.039 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:31.200 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:31.200 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:31.200 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:31.200 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:31.200 WSACleanup called. | 2021-10-29 10:49:31.221 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:31.222 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:31.222 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:31.222 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:31.222 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:31.361 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:31.361 DTC Client socket (2) | Closed. | 2021-10-29 10:49:31.361 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:35.232 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:35.235 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:35.236 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:35.236 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:35.236 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:35.403 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:35.403 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:35.403 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:35.403 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:35.568 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:35.568 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:35.568 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:35.568 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:35.568 WSACleanup called. | 2021-10-29 10:49:35.585 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:35.586 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:35.587 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:35.587 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:35.587 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:35.731 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:35.731 DTC Client socket (2) | Closed. | 2021-10-29 10:49:35.731 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:39.599 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:39.602 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:39.602 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:39.603 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:39.603 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:39.769 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:39.769 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:39.769 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:39.769 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:39.930 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:39.930 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:39.930 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:39.930 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:39.930 WSACleanup called. | 2021-10-29 10:49:39.949 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:39.950 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:39.950 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:39.951 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:39.951 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:40.091 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:40.091 DTC Client socket (2) | Closed. | 2021-10-29 10:49:40.091 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:43.966 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:43.969 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:43.970 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:43.970 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:43.970 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:44.138 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:44.138 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:44.139 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:44.139 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:44.305 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:44.305 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:44.305 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:44.305 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:44.305 WSACleanup called. | 2021-10-29 10:49:44.317 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:44.319 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:44.319 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:44.319 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:44.319 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:44.472 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:44.472 DTC Client socket (2) | Closed. | 2021-10-29 10:49:44.472 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:48.315 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:48.318 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:48.318 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:48.319 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:48.319 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:48.494 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:48.494 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:48.495 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:48.495 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:48.657 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:48.657 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:48.657 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:48.657 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:48.657 WSACleanup called. | 2021-10-29 10:49:48.681 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:48.682 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:48.682 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:48.682 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:48.682 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:48.818 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:48.818 DTC Client socket (2) | Closed. | 2021-10-29 10:49:48.818 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:52.697 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:52.700 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:52.700 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:49:52.700 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:52.700 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:52.867 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:52.867 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:52.867 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:52.867 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:53.030 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:49:53.031 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:53.031 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:53.031 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:53.031 WSACleanup called. | 2021-10-29 10:49:53.048 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:53.049 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:53.050 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:53.050 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:53.050 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:53.195 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:53.195 DTC Client socket (2) | Closed. | 2021-10-29 10:49:53.195 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:56.632 The message log has been sent to support. | 2021-10-29 10:49:56.632 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2021-10-29 10:49:56.632 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 95.216.233.104. | 2021-10-29 10:49:56.632 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:49:57.064 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:49:57.067 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-10-29 10:49:57.068 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-10-29 10:49:57.068 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:49:57.068 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:49:57.237 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:49:57.238 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:49:57.238 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:49:57.238 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-10-29 10:49:57.404 DTC Client socket (3) | CloseSocket call. | 2021-10-29 10:49:57.404 DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:49:57.404 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:49:57.404 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:57.404 WSACleanup called. | 2021-10-29 10:49:57.416 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:49:57.417 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:49:57.417 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:49:57.417 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:49:57.417 DTC Client socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 10:49:57.571 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:49:57.571 DTC Client socket (3) | Closed. | 2021-10-29 10:49:57.571 Sending of the Message Log is completed. The response was saved to D:\SierraChartTransActMA\Data\MessageLogAnalysis.htm | 2021-10-29 10:49:58.952 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2021-10-29 10:49:59.209 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2021-10-29 10:49:59.209 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2021-10-29 10:49:59.433 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2021-10-29 10:49:59.433 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:50:01.433 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:50:01.437 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:50:01.438 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:50:01.438 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:50:01.438 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:50:01.605 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:50:01.605 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:50:01.605 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:50:01.605 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:50:01.769 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:50:01.769 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:50:01.769 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:50:01.769 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:01.769 WSACleanup called. | 2021-10-29 10:50:01.786 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:50:01.787 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:01.787 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:01.787 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:01.787 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:50:01.933 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:50:01.934 DTC Client socket (2) | Closed. | 2021-10-29 10:50:01.934 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:50:05.794 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:50:05.799 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:50:05.799 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:50:05.800 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:50:05.800 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:50:05.967 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:50:05.967 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:50:05.967 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:50:05.967 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:50:06.129 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:50:06.129 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:50:06.129 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:50:06.129 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:06.129 WSACleanup called. | 2021-10-29 10:50:06.148 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:50:06.149 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:06.149 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:06.149 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:06.149 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:50:06.295 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:50:06.295 DTC Client socket (2) | Closed. | 2021-10-29 10:50:06.295 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:50:10.140 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:50:10.143 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:50:10.144 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:50:10.145 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:50:10.145 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:50:10.313 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:50:10.313 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:50:10.313 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:50:10.313 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:50:10.476 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:50:10.477 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:50:10.477 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:50:10.477 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:10.477 WSACleanup called. | 2021-10-29 10:50:10.492 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:50:10.493 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:10.494 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:10.494 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:10.494 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:50:10.640 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:50:10.640 DTC Client socket (2) | Closed. | 2021-10-29 10:50:10.640 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:50:14.498 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:50:14.501 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:50:14.501 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:50:14.502 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:50:14.502 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:50:14.662 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:50:14.662 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:50:14.662 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:50:14.662 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:50:14.820 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:50:14.820 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:50:14.820 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:50:14.820 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:14.820 WSACleanup called. | 2021-10-29 10:50:14.834 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:50:14.835 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:14.835 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:14.835 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:14.835 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:50:14.979 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:50:14.979 DTC Client socket (2) | Closed. | 2021-10-29 10:50:14.979 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:50:18.847 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:50:18.851 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 10:50:18.852 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 10:50:18.852 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:50:18.852 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:50:19.071 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:50:19.071 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:50:19.071 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:50:19.071 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-10-29 10:50:19.185 DTC Client socket (2) | CloseSocket call. | 2021-10-29 10:50:19.185 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:50:19.185 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:50:19.185 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:19.185 WSACleanup called. | 2021-10-29 10:50:19.200 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:50:19.201 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:19.201 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:19.201 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:50:19.201 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 10:50:19.349 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:50:19.349 DTC Client socket (2) | Closed. | 2021-10-29 10:50:19.349 File >> Disconnect selected. | 2021-10-29 10:50:21.626 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:50:21.626 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:50:21.626 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-10-29 10:50:32.691 CQG WebSocket socket (1) | Closed. | 2021-10-29 10:50:32.692 CQG WebSocket socket (1) | Deleting network socket now after delay. | 2021-10-29 10:51:02.699 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:09.031 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:09.034 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:09.035 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:09.035 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:09.035 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:09.202 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:09.202 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:09.202 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:09.202 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:09.366 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:09.366 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:09.366 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:09.366 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:09.366 WSACleanup called. | 2021-10-29 10:52:09.383 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:09.383 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:09.383 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:09.383 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:09.384 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:09.529 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:09.529 DTC Client socket (1) | Closed. | 2021-10-29 10:52:09.530 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:13.383 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:13.387 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:13.388 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:13.388 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:13.388 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:13.555 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:13.555 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:13.555 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:13.555 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:13.717 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:13.718 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:13.718 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:13.718 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:13.718 WSACleanup called. | 2021-10-29 10:52:13.735 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:13.737 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:13.737 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:13.737 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:13.737 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:13.892 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:13.892 DTC Client socket (1) | Closed. | 2021-10-29 10:52:13.892 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:17.739 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:17.742 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:17.743 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:17.743 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:17.743 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:17.913 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:17.913 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:17.913 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:17.913 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:18.081 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:18.081 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:18.081 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:18.081 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:18.081 WSACleanup called. | 2021-10-29 10:52:18.095 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:18.096 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:18.096 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:18.096 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:18.096 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:18.246 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:18.246 DTC Client socket (1) | Closed. | 2021-10-29 10:52:18.246 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:22.101 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:22.106 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:22.106 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:22.106 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:22.106 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:22.275 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:22.275 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:22.275 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:22.275 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:22.441 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:22.441 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:22.442 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:22.442 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:22.442 WSACleanup called. | 2021-10-29 10:52:22.452 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:22.455 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:22.455 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:22.455 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:22.455 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:22.606 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:22.606 DTC Client socket (1) | Closed. | 2021-10-29 10:52:22.606 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:26.471 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:26.474 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:26.474 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:26.475 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:26.475 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:26.643 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:26.643 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:26.644 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:26.644 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:26.808 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:26.808 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:26.808 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:26.808 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:26.808 WSACleanup called. | 2021-10-29 10:52:26.822 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:26.824 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:26.824 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:26.824 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:26.824 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:26.974 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:26.974 DTC Client socket (1) | Closed. | 2021-10-29 10:52:26.974 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:30.845 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:30.848 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:30.849 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:30.849 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:30.849 Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:31.020 Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:31.020 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:31.020 Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:31.020 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:31.185 DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:31.186 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 10:52:31.186 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:31.186 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:31.186 WSACleanup called. | 2021-10-29 10:52:31.212 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:31.216 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:31.216 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:31.216 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:31.216 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 10:52:31.351 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:31.351 DTC Client socket (1) | Closed. | 2021-10-29 10:52:31.352 File >> Disconnect selected. | 2021-10-29 10:52:33.752 DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:33.752 Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:33.752 |
| [2021-10-29 15:00:10] |
| Spinoza - Posts: 62 |
You are not alone. See Not able to download chart data using Rithmic
| [2021-10-29 15:39:43] |
| madness99 - Posts: 35 |
Same here. It was working fine then it just disconnected me. Now I can't reconnect. Rithmic works fine with Ninja Trader and RTrader Pro |
| [2021-10-29 16:46:48] |
| John - SC Support - Posts: 48449 |
We have heard back from Rithmic and they state that they have fixed the issue. You should be able to connect now.
