Date/Time: Fri, 06 Nov 2026 08:40:53 +0000
I can't sign up on the Sierra chart
View Count: 961
[2021-10-29 14:54:33]
User696827 - Posts: 15
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 10:52:33.512
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 10:52:33.514
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 10:52:33.515
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 10:52:33.515
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 10:52:33.515
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 10:52:33.635
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 10:52:33.635
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 10:52:33.635
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 10:52:33.635
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 10:52:33.761
DTC Client socket (1) | CloseSocket call. | 2021-10-29 10:52:33.761
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 10:52:33.761
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:33.761
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 10:52:33.761
DTC Client socket (1) | Closed. | 2021-10-29 10:52:33.761
WSACleanup called. | 2021-10-29 10:52:33.776
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 10:52:33.777
DTC Client socket (0) | CloseSocket call. | 2021-10-29 10:52:33.777
Rithmic Direct - DTC | Disconnected. | 2021-10-29 10:52:33.777
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 10:52:33.777
[2021-10-29 15:59:02]
Have you gone through all the Setup Instructions for Rithmic, which can be found at the following link?
Rithmic Trading Platform Service: Setup Instructions
[2021-10-29 16:39:29]
Yes,
I use Rithmic trade like one week, and today showed me this error.
[2021-10-29 16:41:20]
I contacted my broker to,
Everything on his side is good.....
[2021-10-29 16:46:05]
We have heard back from Rithmic and they state that they have fixed the issue. You should be able to connect now.
