Date/Time: Fri, 06 Nov 2026 08:40:50 +0000
Adding a Menu Item or Subitem, or Drawing Property
View Count: 991
| [2021-10-28 23:11:27] |
| Sierra123 - Posts: 33 |
I have addition attributes and functionality that I would like to enable for a Drawing Object. For example: I put a circle above price on the chart, but I would also like either a a) tooltip if you hover over the circle to pop-up b) an additional property that I could add to the Chart Drawing property and reach through the right-click menu. I also have a function that I would like to call either a) through the tooltip b) via adding another menu item on the right-click menu that can be used for this Drawing Object. Are any of these features possible for me to implement within the Sierra charts studies interface? |
| [2021-10-31 19:04:02] |
| Sierra_Chart Engineering - Posts: 25390 |
It is possible for ACSIL to add menu commands: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events This is all regarding your questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
