Date/Time: Fri, 13 Nov 2026 23:16:34 +0000
Adding additional CME data
View Count: 1197
| [2021-10-28 19:17:08] |
| User148596 - Posts: 217 |
Where can I see prices for adding CME data for bitcoin, ETH and us equities? Thanks. |
| [2021-10-28 23:50:00] |
| John - SC Support - Posts: 48527 |
We are not understanding your question. The CME does have Bitcoin and Ethereum futures, which are part of the CME exchange. But we certainly do not understand what you might be looking for in terms of US Equities. If you are looking for the Cryptocurrency trading itself, then we have data from Binance, Bitfinex, BitMex, and Deribit. These data feeds are available at no additional cost with Sierra Chart, but they do require that your Global Settings >> Data/Trade Service Settings >> Current Selected Service is set to SC Data - All Services in order to get the data. You may want to install a second Sierra Chart in order to get the data. The U.S. Equities data is available through our Sierra Chart Exchange Data Feed. Refer to the information on this page: Sierra Chart Exchange Data Feed And refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-29 15:56:55] |
How do I get data for equities in Sierra Chart?
| [2021-10-29 16:17:43] |
The U.S. Equities data is available through our Sierra Chart Exchange Data Feed. Refer to the information on this page: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-05-17 01:07:30] |
| chrstfer - Posts: 7 |
Sorry to necro an old thread, but I can't find the CME micro ethereum futures anywhere in SC. I've searched the main site and this support board, and that led me here so I thought I'd ask.
| [2023-05-17 13:39:45] |
The Micro Etherium is available and is listed under the "Futures - CME" section on the Find Symbol window. But, we see that you are connected to the Trading Evaluator, and this particular symbol is not setup for the Trading Evaluator (not all symbols are available in the Trading Evaluator). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-05-17 13:50:10] |
That'd be it then. I'm switching over this weekend probably, just need to work out opening an account. Thanks!
| [2023-05-18 19:35:30] |
| Sierra_Chart Engineering - Posts: 25424 |
We will add that symbol to the Trading Evaluator now. However, it will not go into effect until the weekend.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-18 19:36:07
| [2023-05-22 11:00:03] |
We apologize we did not yet get this done but we are doing it now.
| [2023-05-22 11:19:55] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will not be able to trade this yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-05-22 11:38:54] |
You guys are awesome, thank you so much. Take your time, I'm in no rush, but thank you truly.
| [2023-05-22 12:40:58] |
You are able to trade the symbol now. Let us know if any issues.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-22 12:41:08
