Date/Time: Fri, 06 Nov 2026 08:40:54 +0000
TPO excluding evening/premarket sessions does not work
View Count: 1350
[2021-10-28 16:37:02]
User30743 - Posts: 399
there is an option to "exclude evening session" from TPO but when I click it, it does not really do much.
see before https://prnt.sc/1xmiwe2
see after https://prnt.sc/1xmiz3g
the profiles are basically, the same. the only way to exclude the evening session actually go to the chart setting and unclick USe Eveenign Session - https://prnt.sc/1xmj4ln
but why is it so cumbersome? why is the evening session not excluded when I click to exclude it? I don't get it.
[2021-10-28 17:03:33]
What you are seeing looks correct (changing the Input for Exclude Evening Session Profiles Except for Last Day. Keep in mind the amount of trading that occurs during the day session versus the evening.
Keep in mind that the evening session is still included in the most recent profile unless you change the Input for New Period at Day Session Start When Using Evening Period. So that one profile will not look different if you have not set this Input to Yes.
[2021-10-29 15:57:11]
and what are this links for?
https://prnt.sc/1xqjf2c
and how to get rid of them?
[2021-10-29 16:20:58]
Most likely those are the Initial Balance and Point of Control lines. Refer to the following sections of the documentation:
Time Price Opportunity (TPO) Profile Charts: Initial Balance Range
(and the 5 sections after the above that are all related to Inputs for the Initial Balance Range)
Time Price Opportunity (TPO) Profile Charts: Extend TPO Point of Control
