Date/Time: Fri, 06 Nov 2026 08:53:17 +0000
Error when using Text/CSV Data Format
View Count: 1112
[2021-10-26 11:41:56]
User722856 - Posts: 81
Hi Sierra,
I would like to report a problem when using Text/CSV Data Format.
Basically nothing gets displayed, after Importing the CSV, regardless if Daily or Intraday Data.
I Read and followed the Instructions bellow
Exporting and Importing Intraday Data Files
Text/CSV Data Format: Supported Data Line Formats
When using Example (saved as CSV) from:
Text/CSV Data Format: Example for Daily Data
I get the following error
http://www.sierrachart.com/image.php?Image=1635248432191.png
Text/CSV Data Format: Example for Intraday Data
http://www.sierrachart.com/image.php?Image=163524845957.png
Am I missing something or is there indeed a BUG displaying this?
Thanks for looking into it.
Regards
Date Time Of Last Edit: 2021-10-26 11:52:46
[2021-10-26 15:13:52]
Both the images of the error are blank, so we are not seeing the error. Please give us the information on the error you are seeing and when you are receiving it.
[2021-10-26 15:32:53]
Sorry for the confusion, the screen gets blank after a few seconds displaying "Symbol settings not found for current service".
My Service is "no service", as described in the manual.
Bellow once again all the steps and the resulting error:
Step-1: csv file
https://up.picr.de/42323958nt.png
Step-2: how I import
https://up.picr.de/42323955sj.png
Step-3: how i choose the file
https://up.picr.de/42323956ix.png
Step-4: error
https://up.picr.de/42323957xw.png
Date Time Of Last Edit: 2021-10-26 15:36:30
[2021-10-26 15:37:00]
Attach the text data file you are using here. That is the only way we can look into the problem.
Instructions:
[2021-10-26 15:55:16]
I have attached the File, thanks
Private File
[2021-11-08 18:07:14]
Was the attached File helpful ?
Can provide more files if needed.
Happy to help.
[2021-11-08 20:20:07]
Sorry for not getting back to you on this sooner. The issue is simply that you need to have one more line at the end of the file. Just edit the file and put a return at the end of the current last line and then it will be fine.
