Date/Time: Fri, 06 Nov 2026 08:40:01 +0000
Allow Zero Values switches autmatically back ON, when changing the chart symbol
View Count: 897
| [2021-10-14 17:54:34] |
| ticinotrader - Posts: 431 |
Dear Support, I try to disable the Chart Settings - Advanced Settings - Allow Zero Values option, but after I change the chart's symbol, it automatically switches back to Enabled mode. Can you please advise, where/how can I disable this option permanently on a given chart? I am using the latest 2320 version of Sierra. Thank you. |
| [2021-10-29 16:25:21] |
| Sierra_Chart Engineering - Posts: 25390 |
This is controlled through the Global Settings >> Symbol Settings for the symbol or symbol pattern.
