Date/Time: Fri, 06 Nov 2026 08:13:45 +0000
Online trading.
View Count: 3483
[2021-10-11 16:32:31]
Darksound - Posts: 56
Is online trading supported?
I remember seeing some posts about that awhile ago, but can't find it?
[2021-10-11 16:52:37]
We assume you are referring to a web portal, or some other method for trading outside of the main Sierra Chart software.
If that is the case, then we do have our Web Portal for accessing trades that are done with the Sierra Chart Order Routing. It only works for that particular service, it does not work with other trading services.
For more information, refer to the following:
Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel (Mobile Device Access)
