Date/Time: Fri, 06 Nov 2026 08:05:16 +0000
can not update sumbol
View Count: 1028
[2021-10-06 15:25:30]
User313942 - Posts: 17
Software version: 2315 64-bit | 2021-10-06 11:23:07.336
Primary Thread ID: 12620 | 2021-10-06 11:23:07.336
Usage end date: 2021-10-25 | 2021-10-06 11:23:07.336
Enabled for: Sierra Chart Historical Data Service. | 2021-10-06 11:23:07.336
Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-06 11:23:07.336
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-06 11:23:07.336
Current selected Data/Trading service: BitMEX Trading Direct | 2021-10-06 11:23:07.336
Custom symbol settings values: enabled | 2021-10-06 11:23:07.336
Chart Update Interval: 40 | 2021-10-06 11:23:07.336
Intraday Data Storage Time Unit: 1 | 2021-10-06 11:23:07.336
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-10-06 11:23:07.336
2021-10-06 15:23:07 Local computer time in UTC | 2021-10-06 11:23:07.336
2021-10-06 11:23:07 Local computer time in SC Time Zone | 2021-10-06 11:23:07.336
2021-10-05 17:23:24 Server time in UTC | 2021-10-06 11:23:07.336
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-10-06 11:23:07.336
Program path: C:\SierraChart\SierraChartTransActMA\ | 2021-10-06 11:23:07.336
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2021-10-06 11:23:07.336
OS Version Number: 10.0 | 2021-10-06 11:23:07.336
Locale Setting: C | 2021-10-06 11:23:07.336
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-10-06 11:23:07.337
Allowed protected custom studies: | 2021-10-06 11:23:07.337
Requested symbol settings for service code bitmex.exchange.trading. Request ID: 24. | 2021-10-06 11:23:22.199
Symbol settings received. Request ID: 24. | 2021-10-06 11:23:22.643
The response for symbol settings was empty, so the symbol settings file was not created or modified. | 2021-10-06 11:23:22.643 *
[2021-10-06 18:52:23]
Sierra_Chart Engineering - Posts: 25390
Is there anything unusual with how you are connecting to the Internet? Not sure why you are not receiving the symbol settings.
[2021-10-06 19:02:40]
User651547 - Posts: 68
No . it is regular connection . i trade with transact without problem. what can be resone?
[2021-10-07 01:09:57]
We are checking on this.
[2021-10-07 01:26:35]
How do you start Sierra Chart?
Do you start from within the Transact software? Or do you start it directly?
Sierra Chart Support
[2021-10-07 04:02:52]
i start from Transact.
[2021-10-07 16:47:18]
Try starting Sierra Chart directly. Let us know if you are able to get the symbol setting that way.
[2021-10-07 16:51:05]
yes i have symbols but most of them no work , pls see attached. i try use BCHUSD. how i solve this problem.
imagebch.png / V - Attached On 2021-10-07 16:51:02 UTC - Size: 170.6 KB - 319 views
[2021-10-07 23:41:59]
@User651547 you are posting from an expired Sierra Chart account.
Can you please post using the same Sierra Chart account that you are using with Sierra Chart, this helps us resolve the issues for you faster.
You select "Help >> Support Board", to automatically login using the correct account.
