Date/Time: Fri, 06 Nov 2026 08:17:21 +0000
Questions
View Count: 812
| [2021-09-23 16:10:38] |
| User467494 - Posts: 34 |
I have today received this message from Advantage Futures: "Beginning October 1st, TT is implementing new Market Access Provider fees for all clients who connect to the Eurex exchange through SierraChart. Because of this new fee, Advantage Futures is no longer going to be offering Eurex access through the SierraChart/TT connection, and we will need to remove your access as soon as possible. The easiest solution would be to transfer your execution feed to CQG instead. You would still be accessing market data from Sierra’s Denali feed, the only significant difference from your end would be an added $10 monthly charge for CQG. Please let us know if you would like to proceed using CQG and I will set up your new platform. We will need to remove your Eurex access through TT by the end of the day tomorrow either way. Let us know if you have any questions about this." What OTHER options can you suggest in terms of brokers, to continue on using SIERRA CHART execution and data as I've been using with Advantage Futures? Let me know ASAP. Many thanks. |
| [2021-09-23 18:08:04] |
Right now you need to use CQG if you need to trade EUREX. We will be offering direct routing to the EUREX ourselves, independent of CQG and TT and other providers. This soonest we would expect that to come would be in December. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-23 18:08:11
| [2021-09-23 18:11:36] |
Thanks. I also saw the timeline in Eurex to be around the end of the year.
| [2021-09-23 18:17:46] |
Yes we will work hard to ensure that is the case. Now that we are going to be releasing our direct CME routing in October, EUREX is going to be relatively easy to release.
