Date/Time: Fri, 06 Nov 2026 08:17:12 +0000
problem
View Count: 768
| [2021-09-23 16:02:44] |
| User830657 - Posts: 10 |
hi , just change sim mode to my real account and cant place an orders , see attached file please THX https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=55016 |
| [2021-09-23 16:30:21] |
| John - SC Support - Posts: 48449 |
The message is stating that you are in Trade Simulation mode. Refer to the following: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-23 16:30:51] |
You need to disable Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
