Date/Time: Fri, 06 Nov 2026 08:17:08 +0000
New symbol in old chartbook
View Count: 831
[2021-09-23 15:07:51]
ssangha84 - Posts: 132
Hello, I have a chartbook set up with all of my preferences and charts ready with everything I currently look at for CL. I want to add the ES with the same exact settings but I don't want to have to redo all of my settings and charts all over again for the ES. Would it be possible to somehow just load the ES into my current chartbook settings so I don't have to redo everything? Thanks
[2021-09-23 15:23:03]
The easiest thing is to create a new Chartbook for the ES and then in the old chartbook select Chart >> Duplicate All Charts to Chartbook and specify the new chartbook as the destination. Refer to the following information:
Chart Menu: Duplicate All Charts to Chartbook (Chart menu)
Once all the charts are copied, then you can just update the symbol for each of the charts in the new Chartbook. If you already have the charts linked to use the same symbol, then you can just change the symbol of one chart and all the rest will update. Refer to the following for Chart Linking:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
