Date/Time: Fri, 06 Nov 2026 08:17:11 +0000
My intraday charts have big missing gaps in them. Using rithmic from OneUpTrader for data
View Count: 953
[2021-09-22 23:07:02]
ElKimoBasha999 - Posts: 22
Hey there, my daily chart looks fine, but when I switch to anything intraday like 5min or 30min, then it only shows today then skips everything and goes like 2 weeks back, everything in between missing?
I dont have any denali feed, I only bought the advanced package, and then used the rithmic username and password from OneUpTrader to connect.
It shows a green connected status, and I am using the Rithmic Direct - DTC (trading) current selected service.
I will attach the daily (looks fine) but then intraday with huge gap missing.
(I tried the delete and download, and restarted still same thing)
My daily attachment (looks fine): http://www.sierrachart.com/image.php?Image=163235174530.png
My intraday thats messed up: http://www.sierrachart.com/image.php?Image=1632351898874.png
I will attach seperately all the other options of connection and what not, thanks
imageScreen Shot 2021-09-22 at 3.54.29 PM.png / V - Attached On 2021-09-22 23:05:48 UTC - Size: 2.08 MB - 360 views
imageScreen Shot 2021-09-22 at 3.55.49 PM.png / V - Attached On 2021-09-22 23:06:01 UTC - Size: 1.88 MB - 359 views
imageScreen Shot 2021-09-22 at 3.54.35 PM.png / V - Attached On 2021-09-22 23:06:40 UTC - Size: 2.08 MB - 370 views
[2021-09-23 00:26:07]
This is simply the issue we see with historical data from Rithmic. What you are getting is whatever data you received while you were connected to them. The only solution is to use the Denali Exchange Data Feed rather than the Rithmic data.
