Date/Time: Fri, 06 Nov 2026 08:17:15 +0000
Draw Zero Values
View Count: 1201
| [2021-09-22 08:37:28] |
| User669396 - Posts: 7 |
Hi Im trying to get an RSI study to draw a histogram and display minus values. I have draw type set to bar which is fine. I just cant find how to draw Zeros or minus values. Thanks |
| [2021-09-22 14:47:12] |
| John - SC Support - Posts: 48449 |
Exactly which RSI study are you using and how do you have it setup to show you negative values? There should not be any issue with showing negative numbers though. Zero values are set to show in the RSI and RSI-W, but not the RSI-TS studies. It would be helpful if you can give us a screenshot of what you are seeing as well. You can get a screenshot by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
