Date/Time: Fri, 06 Nov 2026 08:17:11 +0000
[Programming Help] - Error retrieving intraday futures historical data through DTC
View Count: 973
| [2021-09-22 08:22:19] |
| abuqutaita - Posts: 12 |
I'm unable to download historical intraday data for futures, although the same code seems to work for daily futures data and also stock data (intraday and daily both). Here's a few things I've tried: 1. Symbol=ESZ20-CME, RecordInterval=60 Sent: header=b'\x13\x00 \x03', message=b'\x08\x01\x12\tESZ20-CME <'
Received: RequestID: 1 RejectText: "Request is not authorized." RejectReasonCode: HPDR_GENERAL_REJECT_ERROR 2. Symbol=ESZ20, Exchange=CME, RecordInterval=86400 Sent: header=b'\x15\x00 \x03', message=b'\x08\x01\x12\tESZ20-CME \x80\xa3\x05'
Received: MessageText: "Data is being downloaded from a remote source. Download will start when this is done." 3. Symbol=SPY, RecordInterval=60 Sent: header=b'\x0f\x00 \x03', message=b'\x08\x01\x12\x03SPY <8\x07'
Received: MessageText: "Data is being downloaded from a remote source. Download will start when this is done." Please advise, thanks! Date Time Of Last Edit: 2021-09-22 17:21:22
| [2021-09-22 17:07:52] |
After some more testing, I narrowed down the issue to only the CME / CBOT / NYMEX / COMEX exchanges. CFE, EUREX, and others appear to work as expected for historical futures data. Is historical/delayed data via DTC not allowed for CME exchanges? |
| [2021-09-22 19:40:14] |
Found this post while searching for something else: not going to allow CME Group historical via DTC server I guess I’m SOL. Consider this question resolved.
| [2021-09-22 20:03:28] |
No it is not allowed based on exchange rules which apply to Sierra Chart.
